Hydraulic Book
Hydraulic Book
What are the best books for teaching and explaining hydraulic theory from basic through to advanced theory?
I need these sources to be authoritative and credible, but also include good explanations and examples. Multiple books are required I assume, but if a book tried to cover everything in one shot that would be interesting too.
I plan to use this book or books as references in writing and producing literature for not only my company, but also for a state and national organization.
The literature to be written I would describe as "popularization" of advanced technical concepts, intended to give lower level persons access to the concepts while not necessarily making them capable of design and responsibility.
Thank you for any help you can provide.
PUMPDESIGNER
RE: Hydraulic Book
RE: Hydraulic Book
RE: Hydraulic Book
RE: Hydraulic Book
RE: Hydraulic Book
If these other links check out OK can i suggest adding them to the links (click the links tab above)?
RE: Hydraulic Book
PUMPDESIGNER
RE: Hydraulic Book
mdshydroplane
mdshydroplane
RE: Hydraulic Book
RECOMMENDED READING
HYDROLOGY: CRITICAL STATE FLOOD: HYDRAULICS 1991
ACKERS P., 1978 Weirs and flumes for flow
W.R. WHITE, measurement
J.A. PERKINS and Wiley
A.J.M. HARRISON
ATTEWELL P.B. and 1976 Principles of Engineering Geology
I.W. FARMER Chapman and Hall
BRUCE J.P. and 1966 Introduction to hydrometeorology
R.H. CLARK Pergamon
BRYAN R. and 1982 Badland geomorphology and piping
A. YAIR Geo Books
CARSON M.A. and 1972 Hillslope form and process
M.J. KIRKBY Cambridge U.P.
CLARK L. 1988 Water wells and boreholes
OUP, Halsted/Wiley
CERNICA J.N. 1982 Geotechnical engineering
Holt, Rinehart and Winston
CHADWICK A.J. and 1986 Hydraulics in civil engineering
J.C. MORFETT Allen and Unwin
COOKE R.U. and 1976 Arroyos and environmental change
R.W. REEVES in the American south-west
DeWIEST R.J.M. 1965 Geohydrology
Wiley
DOMENICO P.A. and 1990 Physical and chemical Hydrogeology
F.W. SCHWARTZ Wiley
GREGORY K.J. and 1973 Drainage basin form and process
D.E. WALLING Edward Arnold
GREGORY K.J. and 1974 Fluvial processes in instrumented
D.E. WALLING watersheds edt. Inst.Brit.Geog.
Special Publication 6
HAUSMANN M.R. 1990 Engineering principles of ground
modification
McGraw-Hill
IASH 1974 Flash floods symposium 112
International Association for
Hydrological Sciences
JACKSON N. 1980 Civil engineering materials
Macmillan
LAMBE T.W. and 1979 Soil mechanics
R.V. WHITMAN Wiley
NOVAK P., 1990 Hydraulic structures
A.B. MOFFAT, Unwin, Hyman/ Chapman Hall
C. NALLURI and
R. NARAYANAN
PEREIRA H.C. 1973 Land use and water resources
Cambridge UP
RODDA J.C., 1976 Systematic hydrology
R.A. DOWNING and Newnes
F.M. LAW
SMITH R.E. 1987 Foundations and excavations in
decomposed rock of the Piedmont
province
ASCE Special Publication 9
edt: R.E. Smith
SOPPER W.E. and 1967 International symposium on forest
H.W. LULL Pergamon Press
TCHOBANOGLOUS G. 1981 Wastewater engineering: collection
and pumping of wastewater
McGraw-Hill
YATSU E., 1975 Mass Wasting
A.J. WARD and Geo Abstracts Ltd
F. ADAMS
YEVJEVICH V. 1972 Probability and statistics in
hydrology
Water Resources Publications,
Colorado, USA
YEVJEVICH V. 1972 Stochastic processes in
hydrology
Colorado, USA
YOUNG A. 1980 Tropical soils and soil survey
Cambridge UP
ZENKOVICH V.P. 1967 Processes of coastal development
edt: J.A. Steers
Oliver and Boyd
USGS Professional Papers
US Soil Conservation Service USDA
US Forest Service
New Civil Engineer
Soil Water Conservation Engineering Schwab et al
New Zealand Journal Hydrology
All recommended sources
Happy 14 years ahead of you ! I have managed 37 and gone into Fluid Mechanics of plane flow systems interface, but that was UCW Aberystwyth’s “fault” for being so good at the course !
Remember the number of Structures people interested in hydraulics hydrology is low so if you can get to grips with flow mechanics and shear, seepage and geologic, soils work for Design you are a little Unique and works such as Richards and Hey are the rarity, The European on the Montenegro waste tip collapse are interesting articles and you can do worse than read The Guardian and Daily Telegraph news manuscripts on main projects. I suggest looking at a 3D computation software such as MicroGrafx simply 3D and some landscape modelling, you will need all the 3D imagination and preparation you can arrange as well as the photography and subsurface geologic sections, simple observations of surface channel hydraulics and all the plane flow patterns.
But try to think in terms of water flows in fissures and pore space, materials, plane elements and deflection and atmospheric dynamics of cell vapour transfers and you will be well set.
I would not read The New Scientist, try to stay with the physics systems works,
After all Hydrology is a Physical System and Structures are about reality Design, not politics.
Look at Web forums for hydrometeorology, satellite weather and statistics on Australian Climate effects on land use and agriculture and reliability (well researched), then there are the sedimentary basin geomorphology and tectonics sites when you want to become adventurous and get serious about flow and engineering structures. Always check the pipe flow people, they, because of Venturi, Chezy, Froude produce the best hydraulics analyses for structures hydrology. Can send you a CD book but it would require an address not encouraged by the forum and may be more than you wish to endure at present.
Pipeflow is best assessed by searching the formula for your own particular pipe systems and that can be started by using standards hydraulics texts such as Tchobanoglous and Novak, but the treatments are specific.
MikeHydroPhys
mdshydroplane
RE: Hydraulic Book
PUMPDESIGNER
