Search for string in excel cells
I'm trying to write a macro that will delete a column in excel if the title has a certain sequence of letters.  I can't seem to get the syntax right, or maybe im going about it in completely the wrong way as im an absolute novice when it comes to writing in VBA.  So far i've got:
Sub Test_Deleting()
    Dim Looking As Long
    Dim TotalColumns As Long
    Looking = 0
    TotalColumns = Application.WorksheetFunction.CountA(Range("1:1"))
    Do While Looking <> TotalColumns
        Looking = Looking + 1
        If Application.WorksheetFunction.IsError(Application.WorksheetFunction.Search("exp", Cells(1, Looking))) = False Then Selection.EntireColumn.Delete
    Loop
End Sub
I wasn't sure if there was a VBA function to search the active cell for a certain string, so i tried to use the excel functions.  I can get Excel to distinguish between those columns with the string in the title, and those without, but can't seem to get it to work in VBA.
Any help would be appreciated
Thanks SP
RE: Search for string in excel cells
I think this should work
Sub DELETE_EXP()
For MY_COLS = Range("IV1").End(xlToLeft).Column To 1 Step -1
    CURRENT_CELL = Range("A1").Offset(0, MY_COLS - 1).Value
    If CURRENT_CELL Like "exp" Or CURRENT_CELL Like "*exp" Or CURRENT_CELL Like "exp*" Or CURRENT_CELL Like "*exp*" Then
        Columns(MY_COLS).Delete
    End If
Next MY_COLS
End Sub
Is it OK?
Hope this helps.
maybe only a drafter
but the best user at this company!
Cheers! With a little fiddling it now seems to work, but is there anyway to make it not case sensitive, because i found that it would delete "exp", but not "Exp".
Thanks again.
Can't think of a way immediately other than adding Or CURRENT_CELL Like "Exp" and all the other variants.
Hope this helps.
Improved procedure:
Sub DELETE_EXP()
    CURRENT_CELL = Lcase(Range("A1").Offset(0, MY_COLS - 1).Value)
    If CURRENT_CELL Like "exp" Or _
       CURRENT_CELL Like "*exp" Or _
       CURRENT_CELL Like "exp*" Or _
    End If
Next MY_COLS
End Sub
by adding "Lcase()" to the procedure you will get all text in variable in Lover Case and you can compare it with with your strings. Text in cell is unchanged.
Vlado
Thanks Vlado!
