Material Designations - Different ones
Being new to the fourm I'm not really sure where to look and the search feature revealed little help.
One of the materials is listed as S355J2G3. I imagine it is a carbon steel type, I just need to know which code this/these numbers come from so I can cross reference them to US material codes. Thanks.
Brian
Brian
RE: Material Designations - Different ones
S 355 J2G3 -> Fe 510 D1 -> 50 D
http://www.duferco-dll.be/en/30_prod/30_20_qual/tab01.htm
S355J2G3 'IM'
An improved machining, inclusion modified low carbon manganese steel. Summarises Features, Benefits, Properties and Machinability data.
http://www.corusengineeringsteels.com/dwn/files/Product/S355J2G3%20IM.pdf
EN 10025. Hot-rolled Products of Low-alloyed Structural Steel. Delivery Specifications.
S235, S235JR, S235JRG2, S235JO, S235J2G3, S235J2G4, S275, S275JR, S275JO, S275J2G3, S275J2G4, S355, S355JR, S355JO, S355J2G3, S355J2G4, S355K2G3, S355K2G4
http://web.alkar.net/vbv/plate%20steel.htm
BS EN 10025:1993 Hot rolled products of non-alloy structural steels. Technical delivery conditions
http://www.roymech.co.uk/Refer_Docs/Stand_Reg_Steels.html
