Removal of armour
Removal of armour
We have a situation where it is not feasable to use bus (space issue).
Usually, in this application we would use 4 runs of 5kv unshielded 500mcm cable per phase. Our supplier has told use that this cable is no longer available, unless special order, i.e. no orders under 1000ft, and a hefty price to match!
Is there any problems with using 5kv teck and stripping the armour? There is no chance of mechanical damage to the cable (it is in a enclosure from xfmr sec to main breaker).
My only concern is that I will have to get the installation passed by CSA with cable that has no markings on it what so ever. Are there any other concerns?
Tulum
RE: Removal of armour
Have you checked online with supply houses like www.anixter.com www.houwire.com www.graybar.com?
This may pose a problem when it comes to approvals.
http://www.thomasregister.com
and type Cables: Unshielded under Product or Service, which will return 73 companies to approach to with the specs
A few potshots..
http://www.houwire.com/catalog/products.asp?catid=58
http://www.kerite.com/catalog/catalogfiles/5kv_nonshielded.htm
http://www.na.pirelli.com/en_50/cables_systems/energy/product_families/pdf/IV_2WEB.PDF
http://www.okonite.com/Product_Catalog/section2/sheet2.html
