Service pak 3
Service pak 3
Service pak 3 is up at the SW website
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Service pak 3
RE: Service pak 3
RE: Service pak 3
Scott Baugh, CSWP
http://www.3dvisiontech.com
http://www.scottjbaugh.com
FAQ731-376
RE: Service pak 3
thank you
RE: Service pak 3
"I did some check and there was some sort of issue with the SP3.0 install (I know, more "Bugs"). That's the bad news... Now for the good news. The fix was very simple. Simple go to add\remove programs and choose SW2004, select change, then repair. Let the system repair the install (with AV off of course). If you could give that a try then let me know the results."
The repair worked. The SP apparently fixed the stacked balloon instability problem.
RE: Service pak 3
So if your in doubt about a problem, try and do a repair on your installation.
And people say there is no benfit to WI installer... I think we can see there is at least one... THere are more but this is a good one.
Scott Baugh, CSWP
FAQ731-376
