T53-L-11C Turbine Engine
Question:
I need a good answer to what would happen to the T53-L-11C Turbine Engine if you took the original engine, did not upgrade the oil pump, and added a oil filtration system to it that filtered the oil to .03 microns.
Dave
Dave
RE: T53-L-11C Turbine Engine
