ACAD 2004 Mtext Window
Is there a way to make the Mtext window look like the old one, I don't like the "split" window of both the text window and the controls window (why is the "OK" pick so small on this as compared to ACAD2002...)
RE: ACAD 2004 Mtext Window
One thing you can do to help is change your MTEXTFIXED setting from 0 to 1.  This will take the transparency away and will make your text window the same size.
