Looking for the smallest relay, 5VDC coil, 20A@120VAC
Subject says it all....I need a SPST relay, PCB mount, that can carry 20A@120VAC, with a 5VDC coil.
Needs to be as small as possible.  I'd prefer to stay away from solid state relays.
RE: Looking for the smallest relay, 5VDC coil, 20A@120VAC
Where have you looked?  We wouldn't want to suggest places you have already looked....
Aromat,P&B,Omron so far
I've had good luck with the PB (now Tyco) T90 Series.  The NO contact does well with 20 amps but we do switch the current on/off with a triac so the relay is actually a dry contact.
