Buried pipeline
Buried pipeline
Buried pipeline
Dear All,
I would really appreciate if someone could explain to me the above situation.
If I had a flexible pipe buried to a depth of 1.5m in soil beneath 5m of water, how would I calculate the total stress pore water pressure and effective stress at the top of the pipe, assuming the soil is fully saturated?
Best wishes,
Howard
RE: Buried pipeline
The pore water pressure should be equal to the depth of the water.  The effective stress should be equal to the buoyant weight of the soil times the soil depth.  Adding the two together will give you the total stress.  That is, assuming the pore water pressure has reached equilibrium...
Why do you ask?
Please see FAQ731-376 for great suggestions on how to make the best use of Eng-Tips Fora.  See FAQ158-922 for recommendations regarding the question, "How Do You Evaluate Fill Settlement Beneath Structures?"
