Datum Target Symbol Problem in SW04
I'm doing a detail drawing of a casting that I need to define multiple datum target points on. I can place the symbols as I require them however I cannot define the target diameter size that is required (.25" DIA). Every time that I try to do so SW flips me off and tells me the value is out of range (1 to 393.7007874).
Now I know that I was able to do this in SW03 without the annoyance I have now. So if anyone can help me out and tell me WTF is up I'd be very grateful.
The value range seems to indicate a possible conflict between english and metric units (I'm using english) so I have checked my units to ensure there is no conflict. I found nothing obvious. Other than that I can only guess that this is a bug of some kind.
Thanks.
Thanks.
Chris Gervais
Sr. Mechanical Designer
Lytron Corp.
RE: Datum Target Symbol Problem in SW04
Chris Gervais
Lytron Corp.
