Welding parameters
Welding parameters
Were can I find standard values for mig welding.
Basically what im after is a starting point of recommended wire size, wire feed speed, amps , volts, gas flow, travel speed for different size materials and different makes of materials. (preferabbly in metric)
There must be some tables somewhere that give you these values to work to.
Can anyone help.......
RE: Welding parameters
www.infodotinc.com/steelworker1/86.htm
From this point you can use the web to find specific information on GMAW welding parameters for various materials.
Gerald Austin
Iuka, Mississippi
http://www.weldinginspectionsvcs.com
