SAE 4041 galvanizing
Sirs:
Does anybody knows if there is a problem to hot dip galvanize SAE 4041 anchor bolts.I have an opinion on this
that says that this treatment reduces strongly the strength
of the bolt.
Thanks,Capablanca.
of the bolt.
Thanks,Capablanca.
RE: SAE 4041 galvanizing
(do a search, there were some good disscussions on this topic like ~6mo to 1year ago)
nick
(you probably want to have them mechanincally plated.)
You migh check the following website and get an RFQ.
http://www.ktbolt.com/KTGalvanizing.htm
steel?
Capa.
steel have less problems in hot dip galvanizing embrittlment:SAE 4041,1045 or say 1020?Shall I avoid
SAE1045 in my anchor bolt design?
Capa.
Jesus is THE life,
Leonard
Cory
