API-620 legs and angle
API-620 code tank: We have a botton cone with 1/4" reinforcing angle and legs. The legs and angle interfere with each other. Will API-620 code allow the angle to be cut and welded to the legs or the legs to be notched out? I assume the answer is no but thought someone might know of a way around this problem. (note:A knuckle radius can not be used because our verticle height of the cone is limited.)
Any ideas would be appreciated.
clp
clp
RE: API-620 legs and angle
clp
Steve Braune
Tank Industry Consultants
www.tankindustry.com
