Multiple objects scaled
I have put over 100 objects on a drawing by multiple copy function.The object is 3 circles with cross hair centres. Now I have been asked to reduce the size by 50%.The question is do I have to select each set individually then reduce it then move on to the next set. I want them to stay in the same position and just get smaller. Hope someone can help.
RE: Multiple objects scaled
Unless the "object" is a block, I think you are looking at some pretty tedius work.  If it weren't for the cross hairs, I could write you a LISP to scale circles about their centers.
Perhaps the best thing would be to make a block, insert it once then copy it 100 times having set your osnap to center.  Make the block something easy to see, like a large filled red donut.  Use a seaparate layer.  Zoom out so your apeture box is large compared to the circles so you can pick easliy.  Then freeze the block layer and erase using (ssx) the circles and cross hairs.  Then change the block to what you need it to be.
Try this lisp called "mscale". It was given in a previous thread by SpeedCad. Unfortunately I was unable to link to that thread.
This lisp gives the option of choosing anything you wish to scale, not only circles or blocks.
 \__          __   __       | |              /___\    |          |
       \ |¯¯\ |__| |__| /¯¯| |             /         \   |          |
___/ |__/ |__  |__  \__|  \____ /            \ |____/
         |                        2003
(defun escala-ins ()
  (initget
    "Line PoliLine Circle Arc COtas Dtext Mtext Block MLine Spline Elipse Hatch SOlid selection"
  (setq    tipo-objeto
     (getkword
       "\nselect object to scale [Line/PoliLine/Circle/Arc/COtas/Dtext/Mtext/Block/MLine/Spline/Elipse/Hatch/SOlid/selection] <selection>:"
  (if (= tipo-objeto nil)
    (setq tipo-objeto "selection")
  (cond    ((= tipo-objeto "selection") (todos-esc))
    ((= tipo-objeto "Line") (Line-esc))
    ((= tipo-objeto "PoliLine") (poliLine-esc))
    ((= tipo-objeto "Circle") (Circle-esc))
    ((= tipo-objeto "Arc") (Arc-esc))
    ((= tipo-objeto "COtas") (cotas-esc))
    ((= tipo-objeto "Dtext") (dtext-esc))
    ((= tipo-objeto "Mtext") (mtext-esc))
    ((= tipo-objeto "Block") (Block-esc))
    ((= tipo-objeto "MLine") (mLine-esc))
    ((= tipo-objeto "Spline") (spline-esc))
    ((= tipo-objeto "Elipse") (elipse-esc))
    ((= tipo-objeto "Hatch") (hatch-esc))
    ((= tipo-objeto "SOlid") (SOlid-esc))
(defun todos-esc ()
  (setq objetos (ssget))
  (if (/= objetos nil)
    (progn
      (setq num-obj (sslength objetos)
        n        0
      (prompt (strcat "\n*** "
              (rtos num-obj)
              " object(s) selected ***"
      (repeat num-obj
    (setq nom-obj (ssname objetos n))
    (redraw nom-obj 3)
    (setq n (1+ n))
      (if *escala*
    (setq *escala* 1)
      (initget 6)
      (if (setq    escala
         (getreal (strcat "\nEnter scaling factor <"
                  (rtos *escala* 2 3)
    (setq escala *escala*)
      (setq *escala* escala)
      (setq n 0)
      (repeat num-obj
          p-ins   (cdr (assoc 10 (entget nom-obj)))
    (command "_.scale" nom-obj "" p-ins escala)
    (setq n (1+ n))
    (prompt "\n*** no object selected ***")
(defun Line-esc ()
    (progn
        n        0
        n-ent   0
              (rtos num-obj)
      (repeat num-obj
    (if (= "LINE" (cdr (assoc 0 (entget nom-obj))))
      (redraw nom-obj 3)
      (setq n-ent (1+ n-ent))
    (setq n (1+ n))
              (rtos (- num-obj n-ent))
              " l?nea(s) select(s) ***"
      (if *escala*
    (setq *escala* 1)
      (initget 6)
      (if (setq    escala
                  (rtos *escala* 2 3)
      (setq n 0)
      (repeat num-obj
    (setq n (1+ n))
(defun poliLine-esc ()
    (progn
        n        0
        n-ent   0
              (rtos num-obj)
              " objeto(s) select(s) ***"
      (repeat num-obj
    (if (= "LWPOLYLINE" (cdr (assoc 0 (entget nom-obj))))
      (redraw nom-obj 3)
    (setq n (1+ n))
              " poliline(s) selected ***"
      (if *escala*
    (setq *escala* 1)
      (initget 6)
      (if (setq    escala
                  (rtos *escala* 2 3)
      (setq n 0)
      (repeat num-obj
    (setq n (1+ n))
(defun Circle-esc ()
    (progn
        n        0
        n-ent   0
              (rtos num-obj)
      (repeat num-obj
    (if (= "CIRCLE" (cdr (assoc 0 (entget nom-obj))))
      (redraw nom-obj 3)
    (setq n (1+ n))
              " Circle(s) seleccionado(s) ***"
      (if *escala*
    (setq *escala* 1)
      (initget 6)
      (if (setq    escala
                  (rtos *escala* 2 3)
      (setq n 0)
      (repeat num-obj
    (setq n (1+ n))
(defun Arc-esc    ()
    (progn
        n        0
        n-ent   0
              (rtos num-obj)
              " objects selected ***"
      (repeat num-obj
    (if (= "ARC" (cdr (assoc 0 (entget nom-obj))))
      (redraw nom-obj 3)
    (setq n (1+ n))
              " Arc(s) seleccionado(s) ***"
      (if *escala*
    (setq *escala* 1)
      (initget 6)
      (if (setq    escala
                  (rtos *escala* 2 3)
      (setq n 0)
      (repeat num-obj
    (setq n (1+ n))
(defun cotas-esc ()
    (progn
        n        0
        n-ent   0
              (rtos num-obj)
      (repeat num-obj
    (if (= "DIMENSION" (cdr (assoc 0 (entget nom-obj))))
      (redraw nom-obj 3)
    (setq n (1+ n))
              " cota(s) seleccionada(s) ***"
      (if *escala*
    (setq *escala* 1)
      (initget 6)
      (if (setq    escala
                  (rtos *escala* 2 3)
      (setq n 0)
      (repeat num-obj
    (setq n (1+ n))
(defun dtext-esc ()
    (progn
        n        0
        n-ent   0
              (rtos num-obj)
      (repeat num-obj
    (if (= "TEXT" (cdr (assoc 0 (entget nom-obj))))
      (redraw nom-obj 3)
    (setq n (1+ n))
              " text(s) seleccionado(s) ***"
      (if *escala*
    (setq *escala* 1)
      (initget 6)
      (if (setq    escala
                  (rtos *escala* 2 3)
      (setq n 0)
      (repeat num-obj
    (setq n (1+ n))
(defun mtext-esc ()
    (progn
        n        0
        n-ent   0
              (rtos num-obj)
      (repeat num-obj
    (if (= "MTEXT" (cdr (assoc 0 (entget nom-obj))))
      (redraw nom-obj 3)
    (setq n (1+ n))
              " text(s) m?ltiple(s) seleccionado(s) ***"
      (if *escala*
    (setq *escala* 1)
      (initget 6)
      (if (setq    escala
                  (rtos *escala* 2 3)
      (setq n 0)
      (repeat num-obj
    (setq n (1+ n))
(defun Block-esc ()
    (progn
        n        0
        n-ent   0
              (rtos num-obj)
      (repeat num-obj
    (if (= "INSERT" (cdr (assoc 0 (entget nom-obj))))
      (redraw nom-obj 3)
    (setq n (1+ n))
              " Block(s) seleccionado(s) ***"
      (if *escala*
    (setq *escala* 1)
      (initget 6)
      (if (setq    escala
                  (rtos *escala* 2 3)
      (setq n 0)
      (repeat num-obj
    (setq n (1+ n))
(defun mLine-esc ()
    (progn
        n        0
        n-ent   0
              (rtos num-obj)
      (repeat num-obj
    (if (= "MLINE" (cdr (assoc 0 (entget nom-obj))))
      (redraw nom-obj 3)
    (setq n (1+ n))
              " l?nea(s) m?ltiple(s) seleccionada(s) ***"
      (if *escala*
    (setq *escala* 1)
      (initget 6)
      (if (setq    escala
                  (rtos *escala* 2 3)
      (setq n 0)
      (repeat num-obj
    (setq n (1+ n))
(defun spline-esc ()
    (progn
        n        0
        n-ent   0
              (rtos num-obj)
      (repeat num-obj
    (if (= "SPLINE" (cdr (assoc 0 (entget nom-obj))))
      (redraw nom-obj 3)
    (setq n (1+ n))
              " spline(s) seleccionada(s) ***"
      (if *escala*
    (setq *escala* 1)
      (initget 6)
      (if (setq    escala
                  (rtos *escala* 2 3)
      (setq n 0)
      (repeat num-obj
    (setq n (1+ n))
(defun elipse-esc ()
    (progn
        n        0
        n-ent   0
              (rtos num-obj)
      (repeat num-obj
    (if (= "ELLIPSE" (cdr (assoc 0 (entget nom-obj))))
      (redraw nom-obj 3)
    (setq n (1+ n))
              " elipse(s) seleccionada(s) ***"
      (if *escala*
    (setq *escala* 1)
      (initget 6)
      (if (setq    escala
                  (rtos *escala* 2 3)
      (setq n 0)
      (repeat num-obj
    (setq n (1+ n))
(defun hatch-esc ()
    (progn
        n        0
        n-ent   0
              (rtos num-obj)
      (repeat num-obj
    (if (= "HATCH" (cdr (assoc 0 (entget nom-obj))))
      (redraw nom-obj 3)
    (setq n (1+ n))
              " sombreado(s) seleccionado(s) ***"
      (if *escala*
    (setq *escala* 1)
      (initget 6)
      (if (setq    escala
                  (rtos *escala* 2 3)
      (setq n 0)
      (repeat num-obj
    (setq n (1+ n))
(defun SOlid-esc ()
    (progn
        n        0
        n-ent   0
              (rtos num-obj)
      (repeat num-obj
    (if (= "SOLID" (cdr (assoc 0 (entget nom-obj))))
      (redraw nom-obj 3)
    (setq n (1+ n))
              " solid(s) selected ***"
      (if *escala*
    (setq *escala* 1)
      (initget 6)
      (if (setq    escala
                  (rtos *escala* 2 3)
      (setq n 0)
      (repeat num-obj
    (setq n (1+ n))
    (prompt "\n*** no objects selected ***")
(defun c:mscale
       (/ tipo-objeto objetos escala num-obj n nom-obj p-ins n-ent)
  (setvar "cmdecho" 0)
  (setq    error_0    *error*
    *error*    errores
  (command "_.undo" "_begin")
  (escala-ins)
  (command "_.undo" "_end")
  (setq *error* error_0)
  (setvar "cmdecho" 1)
  (prin1)
(defun errores (mens)
  (if (= mens "quit / exit abort")
    (prin1)
    (princ (strcat "\nError: " mens " "))
  (setq n 0)
  (repeat num-obj
    (redraw nom-obj 4)
    (setq n (1+ n))
  (prin1)
(prompt "\n*** new comand MSCALE defined ***")
(prin1)
