Low ph fluid application
I am think about use Goulds pump, but I only have example in clear water application. My application is in very low pH fluid. Sugestions?
RE: Low ph fluid application
what is the Fluid?  what is the ph ('very low' is not very descriptive)?  Flow? Temperature? Pressure?  Pure?  Impurities?  Solids?
Need more information if you want any meaningful answers.
My suggestion is that you consider magnetic drive type pumps . Low pH applications suggest high corrosion and this is precisely what these types of pumps are designed to handle.
Suggest you send an enquiry to one or more of the major pump comanies with the fluid details , flow, head and any other special conditions.
