Corrosion rates of ASTM A106 Gr B in Seawater
I have an uncoated pipe immersed in Seawater (Mediterranean Sea), 60m Water Depth. I have estimated the rate of corrosion to be .2 - .4 mm per year.
Has anyone had experience of pipe in similar conditions. Can you confirm these rates or otherwise.
RE: Corrosion rates of ASTM A106 Gr B in Seawater
Please explain your method to estimate the corrosion rate in sea water.
