PTO shaft adapter
PTO shaft adapter
I have a Deutz DX 160 agricultural tractor with a 1000 rpm pto. I would like to convert it to a 540 rpm. The Deutz dealer said Deutz did not offer an interchangeable pto shaft for this model. I would like to find a gear-reducer that has a female 21 spline input(1000 rpm) with a male 6 spline output shaft(540 rpm). I know there are adapters that slide onto the existing 21 spline, 1000 rpm shaft to convert it to a 6 spline 540 shaft. The trouble with this is your engine is running only about 1/2 of what it was for the 1000 rpm. This reduces your horsepower and lugs the engine. Any and all help will be greatly appreciated!
RE: PTO shaft adapter
I'm not able to help you by myself, but have you try to ask some others dealer, maybe from others trademark?
Or maybe another Deutz dealer that could know another "tip"...
Hope you'll find!
Bye
If you reduce the PTO output velocity through one gear-reducer, the tractor power output is the same. You change speed with force.
Bye
http://www.grainaugers.com/ptoreducer.html
I'd say you hit the nail right on the head with that one
ht
Bill L
SBI
Central Ne.,USA
