Heat Transfer Due to Condensation
Can anyone help with calculating the heat transfer method to be used for steam condensing on cold metal? (i.e. How do I calculate the heat transfer coefficient and what temperature do I use, the steam temperature or the saturated steam temperature?)
RE: Heat Transfer Due to Condensation
I suggest you look up Kern(Process Heat Transfer)..
Wayil@hotmail.com
