2004 drawings
2004 drawings
Has anyone notice that the 2004 drawing functions are a little squirrelly? It's seems that there are little bugs in some of the functions and it's driving me nuts. We made the move this week to 2004 SW/PDM and the following are some of my finds.
1. Datums are very hard to move around and also don't comply with the ANSI standard. The suction cup (triangle) is not an equilateral triangle.
2.Basic dimension boxes are not the same size boxes as the GD&T and datums. (This might have been in 2003 too)
3. Difficult to dimension off a section line (almost impossible).
4. When in lock view focus, things end up in other views.
5. I'm sure there'll be others.
Overall, I'm not very happy with the 2D functionality, but I can still get things done with a little work. I hope SW pays more attention this.
FYI, I have the graphics card that SW recommends.
Let me know your thoughts.....
macduff
macduff
RE: 2004 drawings
1) I have had no problem moving datums. Just click on the "0" dimension, grab the attachment point & drag to any other point of choice.
2) I never use boxes.
3) Thats because you are not meant to! Section lines are to show where a section view is taken, they are not an actual feature of a part. Pick an actual part feature to dimension to. (Hole centre, edge, etc)
4) I have not experienced this.
5) Probably, are you using the latest SP?
Most users aren't!
Most users do!
Apparently they have in SW2005!
Finally ... I try not to have thoughts ... it hurts the brain too much ... anyway, you really would not want to know them ... they are too weird & messed up.
Good luck sorting out your ... ummm ... squirrels.
RE: 2004 drawings
3) If you mean the line in the Parent view. Then just RMB the Section line and click "Edit sketch". Add a Dimension then highlight the line and Rebuild the drawing.
4) That's not true in any of my cases and as far as I know none of our customers are seeing this either.
5) There are people out there that see 2D in SW, to be great and others to see it as you do. You can't make everyone happy, but at least they (SW) try to accomidate everyone. In SW05 they say they spent over 80% or more of their time in 2D. We will see when it comes out.
Scott Baugh, CSWP
http://www.3dvisiontech.com
http://www.scottjbaugh.com
FAQ731-376
RE: 2004 drawings
RE: 2004 drawings
Scott Baugh, CSWP
FAQ731-376
RE: 2004 drawings
Can someone please look at this thread I wrote awhile back and see if it got fixed in 2005.
I pushing to going to 2005 in about a couple months.
Macduff
Meggitt Airdynamics Inc.
RE: 2004 drawings
Example: Solidworks05
You should always fully test new major versions of SW, before you use it for production work anyway.
Scott Baugh, CSWP
For all Newbie's - Welcome to the nerd herd!
FAQ731-376
RE: 2004 drawings
Could somebody tell me how to make hardware (screw, pins, etc) un-sectioned on the broken-out section?
Thanks in advance, Steve
RE: 2004 drawings
I sent in a enhancement request for this.
RE: 2004 drawings
RE: 2004 drawings
You should post this as a new question (post).
Scott Baugh, CSWP
FAQ731-376
RE: 2004 drawings
Thanks!
RE: 2004 drawings
RE: 2004 drawings
SW2004 SP4.1
thanks,
Macduff
RE: 2004 drawings
We see most of your problems listed here also. The datums popping up is annoying. We don't see them until after the dwg is printed. I updated to SP4.2 and so far have not seen it happen. Hope all is well. Talk to ya soon.
ctopher
RE: 2004 drawings
Thanks for the heads up SP4.2
All the best,
Macduff
