A Different Application For A Torque Converter
Could anyone explain (to some degree of detail) why an automatic transmission torque converter could not be used in some capacity as a dynamometer brake.
With the internal stator, impeller and turbine it looks like a possiblity.
If there is a question as to why not simply buy a purpose built unit? The answer, I have all sorts of materials, parts and pieces with the addition of loads of time to do so.
Thanks for anyone's help.
RE: A Different Application For A Torque Converter
I imagine you will have trouble controlling the heat in the fluid, and any variation in heat will vary the load, so it might be difficult to hold a constant load for long enough.
Also water for a waterbrake is VERY CHEAP vs ATF.
pat pprimmer@acay.com.au
Instead of oil I would use water. Cooling the water would be done close to the same as oil. The differences are fluid temp fluctuation and viscosity.
Controlling a load against the torque of the engine will be done by providing a fluid port entrance at a strategic spot, and a fluid port exit at a location determined by the internal design of the unit, and the variation of it's flow-rate. Because of the dynamics of the test procedure, the flow will be done with a closed-loop servo system.
Thank you for interest.
However, I'm not sure if it could be done.
Anyone else's help would be a great help.
Thanks again
Thanks for your help. I really appreciate it
WhackyWheels
