can i export xyz coords to excel
Every one,
I really need to find a way to export xyz values of points in my drawing to an excel sheet for the CMM dept Is there any way.
RE: can i export xyz coords to excel
Not that I'm aware of.
You can import them - Insert\Curve\Curve Through XYZ points
There is a Save as but you can only save it as *.sldcrv
How did you get the points in your SW file to begin with?
Scott Baugh, CSWP
http://www.3dvisiontech.com
http://www.scottjbaugh.com
FAQ731-376
Check out cmmWorks from www.accumetria.com
from (the City of) Barrie, Ontario.
If everything is going well, you have obviously overlooked something
I actually have to create the points myself.  I put them on surfaces I want the cmm to check.  I found the commands I need to including in the api, selectdata x, selectdatay, and selectdata z. I just don't know how to write code.  Is there somewhere i can get a program body and modify it?
Thanks for your responses
We have some sofware called Hollis, I believe.  It does a great job of sucking in SW files and doing various types of CMM magic on them.
John Richards Sr. Mech. Engr.
Rockwell Collins Flight Dynamics
There are only 10 types of people in the world - those who understand binary and those who don't.
