H2 Membrane Separation Equipment Source?
I am looking for COTS membrane separation equipment that can recover H2 from a dilute (1-2% H2) gas stream of H2 and air. The stream is at near atomspheric pressure and < 75 deg. C. Volume is in the 25 CFM range.
Any leads on companies offering such equipment would be appreciated.
RE: H2 Membrane Separation Equipment Source?
Seems you don't have much driving force for separation here, with the stream being at such a low pressure. Whatever you do is going to consume a fair bit of energy relative to the quantity of hydrogen recovered.
The H2 in this application is actually a isotope of H2 and is of high value hence the desire to separate it for recycling. The value of the material changes the economic equation significantly.
OWG007: you're not going to find the device you need on anybody's shelf IMHO. If you want to use a membrane separation method to do a decent job of concentrating your (hopefully deuterium, not tritium!) out of your air stream, you'll need to compress it to at least 100 psig to provide driving force to get it across the membrane- vacuum on the hydrogen side of the membrane would almost certainly not be enough driving force for a membrane of an economical size- but who knows- maybe somebody has a really expensive but hyper-efficient membrane for this job. There are flammability concerns if you compress this mixture...at 2% H2 in air, you're near the LEL even at atmospheric pressure, and an increase in pressure will reduce the LEL further. Compressing the mixture won't be hazard-free.
If the deuterium is really valuable to you, you could consider cryogenic temperature-swing adsorption of the air components, letting the deuterium pass through- but at 30 cfm you'd need a LOT of cooling to accomplish that...
Another option is to combust the deuterium and collect the heavy water by condensation- you can re-generate the deuterium again by electrolysis. Not much use to you if the air stream also contains ordinary water vapour, because you'd be into a very complex separation process to upgrade the isotopic purity again. Perhaps you could scrupulously dry the air stream prior to combusting it- that would help give you the isotopic purity which makes the deuterium valuable.
Sorry, but I don't have any vendors for you to consider.
http://www.genesisfueltech.com/tech.html
Air Liquide/Medal (my company)
UOP
Air Products (I'm pretty sure)
This sounds like a small volume specialty application, so it might not be interesting on a size basis for a gas company. (in other words, not enough $$ to do the the design work, unless you're willing to pay $$$)
The important design criteria for a membrane is pressure ratio, not absolute pressure gradient, so a vacuum pump may work. The explosion issue and residual vacuum oil, I will leave aside for a design engineer. (I'm in membrane R&D)
The real issue to me is how pure do you require your product? Polymeric membranes will not get really high purities from a 1-2% feed, say 50%, with a moderate recovery. (purity and recovery are a tradeoff) If you require high purities, VSA or cryo would be better bets. I believe that someone sells (maybe one of the GC companies??) a Pt/Pd membrane for super pure H2, but the flux is very low.
Dave Hasse
Air Liquide
dave.hasse@airliquide.com
talked to my boss. He pointed out for a high value stream, such as this I assume, multistage membranes with recompression can give much higher purities and better recoveries. At which point I went "doh"...
Dave
You can then regenerate concentrated deuterium wherever/whenever it's needed by electrolysis of the collected heavy water. The idea here is that the deuterium will be far easier to handle and separate from the air stream as heavy water than as a gas.
