Continuous length Molding
I have an opportunity to produce continuous length molded strips of a TPE. A concept is in hand that appears it will work, however, before investing in technology, I'd like some feedback on existing methods you are using. Anyone care to comment and keep us from "reinventing the wheel"...
Thanks and God bless
Mike
Mike
RE: Continuous length Molding
DHuffy
nick
Hmmm...could you explain the profile? Does it continually change throughout the length? Keep in mind that there are secondary operations in the extrusion line that can add shapes and modify the contour of the extrusion that may give you what you need.
Good luck,
Huffy
Could you e-mail me your profile design?
