wet sprinkler system in coal-fired baghouses
fellow engr's,
forgive me for the duplication of this question.  i believe that perhaps this forum's audience may be able to provide additional valued feedback.
i recently encountered this matter and find it, let's just say pathetic thinking for now unless there are justifications for the design.  i am posting this query on behalf of other individuals, but i now understand that another location is subject to the same situation, except that the other location is installing a dry-pipe system.
also, i trust this would be the proper forum to address this matter, even though it does address fire protection issues.
coal-fired boilers with baghouse modules...ID fan located downstream of baghouse modules.
the designer installed a wet-pipe sprinkler system and even had sprinkler heads installed inside the baghouse.  it is my strong opinion that having sprinkler heads (wet ones at that!)inside the baghouse is potentially a serious problem to equipment and/or personnel.  if the system ever activated while boiler is in operation, a potentially serious condition may exist.
is anyone familiar with other installations of similar designs?  if so, what are the justifications, codes/stds, etc.?
any stds/codes that can be referenced to justify/not justify the installation of sprinkler heads inside baghouses?
my opinion, this matter needs attention before a bad situation gets worse.
thanks!
-pmover
