EPR vs. XLPE for MV power cables
Does anyone know what the differences are? I am buying about 20k feet of 5kV power cable and found that the 2 main choices are EPR insulation with a PVC jacket or XLPE insulation with a PVC jacket. What are the tradeoffs of the two?
On a side note should I get shielded cable for this voltage class? I have heard it is difficult to get completely unshielded cable anymore. What is everyone's thoughts?
Thanks for the help.
RE: EPR vs. XLPE for MV power cables
EPR insulation has shown, over the years, a higher resistance to "treeing" of the insulation in the presence of moisture. For industrial projects, at least in the US, EPR is used almost exclusively. While Tree-retardant XLPE has definitely improved, most specifying engineers do not regard it as ultimately as reliable as XLPE. EPR is also regarded as somewhat easier to install.
XLPE has two main advantages - lower cost and lower dielectric losses. The dielectric losses of medium-voltage solid-dielectric cable are quite small in the overall scheme of things, but there is no doubt that XLPE losses are significantly lower than EPR. This (and the low cost) is why utilities still favor XLPE for long runs of URD cable.
For more info on relative pros and cons - just talk with your local Okonite and Southwire reps. They will be able to talk for hours on the subject.
As for shielding - I'd go shielded if I had 20,000 ft.
EPR is more tree resistant than plain old XLPE but Tree Retardent TR-XLPE is just as good as EPR from that standpoint. EPR does tree contrary to some sources; you can't see the trees as easily as in XLPE.
EPR is more flexible and from that standpoint is easier to install, particularly for large sizes.
It can be difficult to strip the semicon from EPR without damaging the insulation.
EPR is not a standard compound like XLPE. There are differences among manufacturers. Make sure that you use a reliable manufacturer.
EPR has higher dielectric losses, but at 5 kV this would be negligible.
I would use shielded cable at 5 kV.
What's the minimum cable-pulling temperature for EPR? We don't pull XPLE below about 4DegC officially, although we occasionally take the chance on a smaller cable for a breakdown repair. I'm guessing that EPR has a much lower minimum pulling temperature: given that the northern US is pretty cold for several months, could this be another reason?
Start each new day with a smile.
Get it over with.
http://www.okonite.com
for more info on EPR cable
http://www.generalcable.com
http://www.generalcable.com/North_America/NorthAMCat.html
for: TRXLP and EPR cable data sheets
http://www.deis.nrc.ca/eim/EIM-Cables.pdf
http://www.deis.nrc.ca/eim/1988.htm
for: References
Along with all the other comments so far, with which I agree, I would add that when it comes to flame tests EPR beats XLPE, for medium volatge applications and up. From my experience you can't get an unarmoured XLPE MV cable with a "Tray Cable" rating. So for applications in tray where "TC" is required unarmoured EPR is likely cheaper than armoured XLPE.
IEEE 525 recommends a minimum pulling temperature of -40C for EPR and XLPE.
XLPE or TRXLPE tends to be preferred where applications might include low temperatures. This is in an agreement with other postings in this thread.
Tree resistance has been discussed, which would suggest EPR for underground or wet applications.
Temperature has been discussed. My experience is that EPR is significantly more flexible, although your choice of PVC as a jacket material means that you will have a stiff cable anyway.
Flame retardance was briefly mentioned. One cannot say that one material is always more flame retardant than any other, but EPR tends to be more flame retardant in general. That's because the standard way to make cable insulation more flame retardant is to dope it up with halogens (mainly chlorine and bromine). They add to the insulating properties of EPR but subtract from the insulating properties of XLPE. As a result, it's easy to make EPR flame retardant and harder to add flame retardance to XLPE. At 5kV and standard insulation thicknesses, though, XLPE can be made reasonably flame retardant.
For cable tray applications and others, XLPE and XLPO are making headway as low-smoke, low halogen insulating and jacketing compounds. Those same halogens that make EPR flame retardant are lethal during a fire. Once again, your choice of PVC as a jacket material suggests that you aren't concerned about low-smoke.
My impression is that the XLPE compounds are VERY similar between manufacturers but there is very little similarity between EPR compounds between manufacturers. They all have their proprietary recipes for EPR. That is why it is very important to use a reputable manufacturer.
The comment above about difficulty stripping EPR insulation is something to consider but the problem has been overcome by the really good manufacturers.
If your utilization voltage is 2.4 kV you might consider unshielded cable. Otherwise don't even think about it. The only manufacturer that I'm aware of who would try to sell you an unshielded cable for >2.4kV is Kerite. Let's just say their opinion differs from the mainstream in that regard.
This time I specify EPR, the salesman say they should be good for 30-40 years, longer than most people will ever remember.
A major institutional operation in an ANSI region has some peculiar text in their CSI Division-16 boilerplate.
High voltage cable (4160 volt and 12000 volt systems) shall be 5KV and 15KV, EPR type, with 133% insulation and shall be warranted for 40 years.
From a procurement/construction-contract standpoint, is this specification enforceable? Is such a terse mandate administratively feasible?RE: EPR vs. XLPE for MV power cables
utilites usually have crews train to deal with cable failures on a day to day basis. but if you are doing work for a plant, you do not that type of trained people available and must contract them out . Which takes a lot of time and lost production. So usually epa is used for plants. But for the power co. the xlpe is the way to go.
Not to oversimplify circumstances, but it may be worth mentioning that there are often inherent differences in operational philosophies of industrial (and institutional) compared to utility electrical-distribution systems. Utilities tend buy and stock larger quantites of very standardized materials and plan on in-house fast-turnaround replacement as needed.
Industrials tend to be geared to specify the original system (and initial capital outlay) using more conservative components and methods, with expectations of fewer repairs by more specialized firms over the life of a facility.
http://www.generalcable.com/North_America/NA_Assets/ProductBrochures/EmpowrLinkSS.pdf
for TRXLPE cable .24 reported failures per 100 miles.
