Searching for Bearings with Hex ID
So far my internet search has only yeilded www.frantz-mfg.com as a source for these types of bearings. I am hoping someone out there knows of a few more sources.
Ray Reynolds
"There is no reason anyone would want a computer in their home."
Ken Olson, president, chairman and founder of Digital Equipment Corp., 1977
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
RE: Searching for Bearings with Hex ID
Ray Reynolds
These bearings are also called implement, disc harrow, conveyer, and so on and are available in all sizes and descriptions with round, hex, and square bores.
This one has all types of bearings
http://www.millerbearing.com/
This one has plastic and SS conveyer bearings.
http://www.kmsbearings.com/convey2.htm
Ray Reynolds
I stopped by a friend's fish house this morning and while having a cup of coffee one of the mechanics that works on equipment stopped and showed me a hex bore bearing and wanted to know where to get about 24 "just like it". Only one problem was that 2 sides were worn and the bore was elongated. Someone had put the bearings on a round shafts.
We are trying the Plastic bearings on a big conveyer.
Ray Reynolds
I'd rather just specify the correct item and have it bin-stocked instead of creating a "make-from" item. But I'll keep this in mind if availability becomes an issue. Thanks.
Ray Reynolds
http://www.youngssurplus.com/bearings_and_couplings.htm
Hope this helps.
