What is the minimum depth to prevent underground pipe from freezing?
Dear Friends,
What resources to look at the minimum depth to prevent underground pipe from freezing (chilled water services with PVC). I am in Enid, Oklahoma. Thank you very much!!!
RE: What is the minimum depth to prevent underground pipe from freezing?
Check with your local building department.  They have codes for minimum clearance for residential water lines that take into account the local frost line.
David Simpson, PE
MuleShoe Engineering
www.muleshoe-eng.com
Thank you very much Mr. Simpson!
thien2002,
AWWA D100, the design code for potable water tanks, has a map with required pipe cover depths to avoid freezing.  It would seem to be exactly what you are looking for in this case.
Steve Braune
Tank Industry Consultants
www.tankindustry.com
Reference to Piping Plant Layout amd Design for cold area form the TOP to Grade 9'-0". or Sit Specification.
lst
Yeah, know where you're heading.
In Canada, four (4) feet minimum will clear a guy from the permafrost(lat=54N).  The further north, the deeper you need to go. Eventually you'll hit bedrock, the Artic tundra has very little topsoil.
But tell you what, up North, little guys like me can hit a long ball just like John Daley.  You get a lot of roll over those outcrops!
Kenneth J Hueston, PEng
Principal
Sturni-Hueston Engineering Inc
Edmonton, Alberta Canada
