large threads
large threads
large threads
i need to draw a part which is essentially 6 threads running along the axis of a large cylinder. I have the equations for the threads and the wrap angle(how far it goes round the cyliinder) could someone please help me. Simple help would be great.
RE: large threads
You have to create these threads with a Helix-based feature.  Look in SW Help for "helix" and that should get you on your way.
You should only have to model 1 thread, then revolve that feature around your cylinder for the other 5.
Ray Reynolds
"There is no reason anyone would want a computer in their home."
Ken Olson, president, chairman and founder of Digital Equipment Corp., 1977
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
RE: large threads
Are the "threads" a contiguous part of the cylinder or are they going to be attached (bolted or welded) to the cylnder in an assembly?
Either way it sounds like you need to use a Sweep. There is a fair amount of good information in the Help files under "Sweep" and also in the On-line Tutorial in 3D Sketching & Revolves & Sweeps.
Basically you need to create the path of the sweep with a helix and a profile of the thread on a plane perpendicular to to the end of the helix. There is a section in the help files which relate specifically to the end conditions of the swept profile.
If the "thread" is to be a part in an assembly, model it seperately, add it to the assy, then create a Circular Pattern
from (the City of) Barrie, Ontario.
If everything is going well, you have obviously overlooked something
