HIC Resistant Carbon Steel
Could anyone explain what makes a Carbon Steel HIC Resistant?
I am involved in a relatively small fabrication where the materials of construction are specified as ASTM A333, A350 LF2, P355, A420 WPL6 but the materials are also specified to be "HIC resistant Carbon Steel".
What steps do we need to take to ensure this requirement is met?
Thanks in advance
RE: HIC Resistant Carbon Steel
These may help a little.
About American Steel Pipe - ACIPCO
AMERICAN Steel Pipe produces high quality steel pipe for high pressure oil and gas
transmission lines, dredge pipe, steel pipe pilings, HIC resistant pipe for ...
www.acipco.com/steel/aboutus.cfm - 11k - Cached - Similar pages
[PDF] Cat. 1 SS PS50 168.3 x 5.2 Grade 359
File Format: PDF/Adobe Acrobat - View as HTML
... Grade 241 (B) to Grade 448 (X65) Low Temp ASTM A53B PS50/PS10 – Proprietary HIC
Resistant for sour service (H2S) applications PRUDENTIAL STEEL Size Range ...
www.prudentialsteel.com/pdf/line_pipe.pdf - Similar pages
Prudential Steel
... Cool HFIW Line Pipe. HIC Resistant Line Pipe. The above files are in PDF
format. ... Hollow Structural Sections(US), PS50 HIC Resistant, ^back to top.
www.prudentialsteel.com/product_info/ product_brochures.shtml - 18k - Cached - Similar pages
[ More results from www.prudentialsteel.com ]
Oil & Gas Line Pipes
... Success Stories HIC resistant line pipe In sour service applications, moisture,
hydrogen sulphide and stress areas in the steel pipe can be a dangerous ...
www.dofasco.ca/content/page_502-640-663-809.shtml - 14k - Cached - Similar pages
Corrosionsource/2000 - Session 11/Paper 1101
... investigation included: (1) the development of SOHIC damage in the base metal and
heat affected zone of both a conventional and “HIC Resistant” grade of ...
www.corrosionsource.com/CS2000/session11/ paper1101/paper1101.htm - 34k - Cached - Similar pages
HICPipe Page
... To minimize the susceptibility to cracking, Stupp Corporation produced HIC-resistant
pipe by utilizing a specially designed chemistry and pipe manufacturing ...
www.stuppcorp.com/hicpipe.html - 19k - Cached - Similar pages
NACE International - The Corrosion Society
... NACE MR0175, "Sulfide Stress Corrosion Cracking Resistant Material
for Oil Field Equipment"; HIC - Performance of Metals and Alloys. ...
www.nace.org/Nace/content/education/ BasicCorrosionOutline.asp - 70k - Cached - Similar pages
HIC and Steel Cleanliness Inspection
... The makers of pipelines, eg more often require "HIC" - resistant steels (HIC =
hydrogen induced cracking), including the corresponding test documentation. ...
www.ndt.net/article/wcndt00/papers/idn153/idn153.htm - 10k - Cached - Similar pages
HIC Weekly Alert | Sample
... Back to top. Resistant bugs and flu create fatal infection. Some child
deaths linked to MRSA. Community-acquired multidrug-resistant ...
www.ahcpub.com/ahc_root_html/hot/hic_sample.htm - 25k - Cached - Similar pages
SUMITOMO METALS : Business : Steel Plates
