What is going on?(charging batteries)
Hi all,
i have 14 cells of Li-iron batteries,
each cell should have 2.75 to 4.25 VDC
which gives a total of (4.25*14 = 95.5V)
also i have a charger which can supply at 24V or 12V only.
and the current rating is up to 20 A
in order to charge the batteries, i have to create voltage difference .
So the voltage of the batteries should be lower than of the charger.
in the charging specification of the batteries, i have found that their general charging is at 33A.
After connecting the 6 cells in series, and then to the charger, i have noticed that the current is about 5amps, and keeps on droping ( because the voltage of the batteries is increasing)
but,i didnt understand , why its charging at 5amps ???shouldnt it be charging at a higher value?
RE: What is going on?(charging batteries)
