Preventive or Preventative
As in "preventive maintenance".
Some dictionaries cite both as acceptable. I don't see what the extra syllable adds.
RE: Preventive or Preventative
David
systemic, systematic
propene, propylene
ethene, ethylene
It could be pomposity, but it may have more to do with diction.
Systematic: Carried on using step-by-step procedures, or relating to classification or taxonomy
Regarding ethene/propene and ethylene/propylene there was a widespread clarification of all organic nomenclature some time ago and the old (and taxonomically weak) forms were replaced with a more formal structure. There is still some use of the old terms (ethylene, propylene) particularly informally. The three main hydocarbon series suffixes became formalised as -ane, ene and -ine with the appropriate prefix for the series member.
Good Luck
johnwm
RandomHouse gives the following:
systemic 1. of or pertaining to a system.
systematic 1. having, showing, or involving a system,
Regarding the suffixes you are correct, (I'm not sure if you are disagreeing or not) with the exception of the triple-bond nomenclature; it is -yne prefixed by the carbon chain.
eg.
C-C-C-C-C pentane (C5H12)
C-C-C-C=C pentene (C5H10)
C-C-C-C_=C pentyne (C5H8)
Sometimes the extra syllable just rolls off the tongue easier. You know once the tongue gets rolling it can be really difficult to stop at times...........................................................................
Jesus is THE life,
Leonard
Both are correct by the dictionary as I'm sure you know. I guess we tend to repeat the useage that we hear.
Thanks for the alternative -yne, which I had overlooked. This seems to be another of the European/US differences, with ILO (and other sources) giving both as alternatives.
With regard to systemic/systematic, I would differentiate between systemic poisoning, which is build-up of a poison agent within a particular bodily system, and systematic poisoning, which is a planned exercise (or system) of poisoning.
Good Luck
johnwm
I would have said ..
The problem was systemic. (A problem that recurrs as a result of following the system)
It was a systematic problem. (A problem with the system not working as expected)
But as mentioned, without checking the dictionary.
