Saving Level names in Ver. 7
Could someone help me? I am having trouble saving level names in my Microstation Ver. 7 files.
I go into the Names dialog box and name the levels I want to use and delete names I don't want (the files I start with sometimes already have some levels named). Then I hit Done. When I go to my level Manager, the levels are named as I set them and everything appears fine. I then go to File and hit Save Settings just before hitting Save. When I reopen the file, the level names are back to what they were before I changed them. Sometimes the levels that I gave new names will have the new names, but the deleted level names always reappear.
What am I missing?
What am I missing?
RE: Saving Level names in Ver. 7
Under Workspace>Preferences>Operation; Make sure that "Immediately Save Design Changes" are on as well as "Save Settings Upon Exit". Another thing you could try is under level names modify the names to what you want then do a "Save as" to a different name. Exit Mircostation, then open the "new" level name structure (.lvl file) you just saved under the level name area.
Good Luck
Champ
I am able to save the level names, but then when I open the file, I still have to manually attach that level scheme to the file. I aslo tried saving the design file with a new name after changing the level names. It did not make a difference.
I have tried your suggestions and still am having problems. I am starting to think my problems are more complicated than the symptoms suggest. I have experienced a few other problems and thought they were separate issues, but not I am beginning to think they are connected.
I am now going to start looking at my workspace settings and settings groups.
In the Level Names dialog box I needed to go to File -> Remove -> OK. Then I make the changes I want, remove the level names I want to remove and select Done. Then I go to the File pull down menu and hit Save Settings.
The changes are still there after I close the file and reopen it.
Just a thought.
