Reinforced concrete deep walls help
I have been trying to find some information out about a deep reinforced concrete rectangular vault I am designing. The dimensions are 26' x 30' x 29' deep. Using "Rectangular Concrete Tanks" I am getting a wall thickness between 22" and 28" based on shear. Does this seem reasonable? It sounds a little big but I don't know how I would determine it otherwise. I am using a lateral force of 135 pcf x 0.6 (at-rest coefficient) based on geotechnical.
Any help with this would be appreciated.
RE: Reinforced concrete deep walls help
I participated in the forensic evaluation of an above ground sewage treatment plant - aeration basin walls had failed. The tank had been designed using ultimate strength design techniques (a precursor to LRFD) instead of ASD. The as-built walls were 14 inches, while ASD would have dictated 20+ inches. Oh, and the basin walls were only about 15 feet high, and the fluid unit weight γsewage = 63 pcf. That's considerably less than the γ = 81 pcf you have assumed, and your wall is twice as high. Your design γ = ( (135-63)*0.6 + 63 ) = 106 pcf if the GWT is at the ground surface.
Proceed with caution...
Perform an ASD design to check your current calculations. If there's a big difference, you have a problem...
Please see FAQ731-376 for great suggestions on how to make the best use of Eng-Tips Fora.
Could you clarify what ASD Design is and where I can find it?
How are you performing the design - by "hand", or computerized design package?
I am performing the computations by hand using PCA's resource "Rectangular Concrete Tanks" to analyze the structure, which gives factors based on finite element analysis for these types of structures.
The working stress would put you at approximately 22,500#/ft of shear at the mid-span (worst point). Without the factored loads, and f'c = 3500psi & 65psi shear,
22500/12(65) = 28.8 inch d. 28.8 + 1/2 bar thickness + 2" cover==> 31+. Your numbers are not out of whack, I did a 75' x 100' x 25' deep recently, had the same order of magnitude. Focht3 has good advice, Best of luck
Tincan.
