colour of iges import
Does anyone know how to (if it is possible even) change the colour of an iges file that has been imported into a part file?
TIA
Andrea
RE: colour of iges import
Aren't you able to use your render control settings under view color and appearance?
It seems that it is only possible to re-colour the surfaces of an iges import and not the part as a whole. This is long winded and therefore, time consuming! I just wondered if anyone knew of another way.
Andrea
Try selecting "quilt". If the surfaces are quilted together, this should work.
Best regards,
Matthew Ian Loew
"Luck is the residue of design."
Branch Rickey
Try this:
View-->Model Detup-->Color and Appearances-->Choose or create your own color-->All surfaces-->Unset-->Part-->Set
It worked for me
im4cad
Pro Design Services, Inc.
http://www.cadproe.com/pds/home.asp
Thanks all!
