Wind Speed and Pressue Design
I'm looking for numbers to verify the design of a valve/flange that a process instrunment is mounted on. The instrument will be used in refinery applications sitting as high as 150 feet in the air mounted on the valve/flange on a process pipe. What wind speed and pressure should I use to verify the design? Thanks for any info.
RE: Wind Speed and Pressue Design
Best of luck.
