another question associated with plate
when analyzing a plate with its aspect ratio larger than 100(nearly 1000),which element type is more appropriate, solid95,solid45 or shell63?
RE: another question associated with plate
What do you mean by aspect ratio? Thickness to length or ratio of lengths? If it's thickness to length then I would say shell63. If it's ratio of lengths I would use a beam element.
