Response Spectrum Analysis & its resullts
When we use the Response Spectrum analysis, because of the mode combination methods (CQC, SRSS) all the results such as forces and moments have the same sign and all are positive. My question is how we can find out which one is positive and which is negative? Which one is tension force and which is compression force? . . . There are some procedures that we can use to find out this, but none of them is practical to use in software. I need a guide that can be used in structural design software such as SAP & ETABS and use analysis results directly to design and Iterate to achieve convergence in final design in shortest possible time.
Thanks a lot.
Thanks a lot.
RE: Response Spectrum Analysis & its resullts
-- drej --
