the elastic modulus of nylon6
Hello,everyone
I am very happy to join this forum,and I am hoping to get more help from you and help you also.
Here I have a problem about the elastic modulus of nylon6.I have done some test to measure the elastic modulus,but the results have a big difference from the value in a paper.I am not sure about it.I will appreciate you help.
RE: the elastic modulus of nylon6
Only test after a period such as 24h, semi-crystalline polymers such as nylon 6 can increase in crystalline content and properties such as E modulus can change as a consequence.
Ensure test geometry & test rate are the same as the literature values you are looking at.
If you register you can get a PDF on Zytel but it is a 916K file.
http://www.boedeker.com/nylonc_p.htm
maybe it help
Mirekp
http://www.mitcalc.com
mechanical engineering calculations
