Ethernet vs. Remote I/O communications
I am designing a control system around A-B SLC500's. There will be one processor on each of two compressors, and one central station processor. The compressor SLCs will communicate with the station PLC as a supervisory control system.
I started to use Ethernet, but the sales engineer suggested Remote I/O, since the distance was 1000' from compressor to central PLCs.
Should I use Ethernet anyway? Wireless Ethernet? Controlnet? Remote I/O?
Any other suggestions? Thanks,
. . . Steve
. . . Steve
RE: Ethernet vs. Remote I/O communications
xnuke
Not as fast as ethernet, but I assume the amount of data passing between stations will be small.
Ken
If the requirements are not very high, then even DH485 could do the trick. That could limit the PLC requirements for the two compressors to SLC5/03's or even less than that.
The most important signals are the remote start/stop commands. Those could be hard-wired between the Station and Compressor PLCs. The other signals (about 200/compressor) are for monitoring purposes from the remote site. They do not need to be gathered often or quickly, since they will be stored in the local (Compressor) PLC/HMI.
We need to know if there is a problem, and what the possible cause is, before sending someone out to the compressor station.
This is good info! Keep the ideas coming!
. . . Steve
