PLOTTING A WINDOW
PLOTTING A WINDOW
I know ploting a window in a model works fine wysiwyg, but how do you plot a window in a drawing????
David A. Johnson
Thunder Systems Inc.
Corona, CA
RE: PLOTTING A WINDOW
Scott Baugh, CSWP
http://www.3dvisiontech.com
http://www.scottjbaugh.com
FAQ731-376
David A. Johnson
Corona, CA
When you click File\Print - what do you see? You should see a menu that contains this -See Below
The "selection" is circled. Once you highlight that you click OK and then you will get the window.
Scott Baugh, CSWP
FAQ731-376
David A. Johnson
Corona, CA
