Is there an error in this formula?
In Section VIII, Div. 1 Paragraph UHX-15.3 lists the following equation:
ff = ratio of the fillet weld strength to the design strength
= [1 - Fg/(fdFt)]
Can this be right?
-Christine
= [1 - Fg/(fdFt)]
Can this be right?
-Christine
RE: Is there an error in this formula?
Recommend you use the Code Case for an extension on your submittals.
Talk to your AIA,the change draft is finished.
The reason I suspected something was wrong here is that the entire formula in enclosed in brackets, for no apparent reason.
Also, for partial strength welds, the fillet weld strength to design strength ratio is typically a negative value. That just doesn't make any sense to me.
-Christine
Just kidding-a lot of work by some very skilled people has gone in to UHX so far. Much more is coming.
