Polystyrene adhesive
We're creating polystyrene parts for a customer of ours, and attempting to glue several scrap pieces together to offer a cost reduction. What kinds of glue (brand names or sources would be great!) would you guys recommend? We're looking for something sprayable, and simple to apply.
Thanks, and have a great day!
RE: Polystyrene adhesive
We have exactly the same "problem". To "weld" chemisly the 2 PS parts, we use a moisture of worn out ABS with acetone...that gives us at the end, a white liquid. It works very well, but the application on the joint gives me serious and anoying problems everyday. At the present time, we are using a pressurized reservatory at 1.5 bar and a comuns air pistol to aplly the liquid on the joint.
It works very well...during 1 or 2 days.. until the pistol become stuck inside, due to the acumulation and solidification of the liquid in the internal walls of the pistol.. and the rubber o-rings destroyed.
I'm looking for a solution to this problem. Can you help me on this?
