Temp/pressure testing HP Butt weld valves
Thread 408-21669 attempts to answer some questions on basic testing on this subject, however I have a high pressure application together with low temp testing. I am looking for a supplier of what I believe to be a clamping method to retain the test flanges. Images I have seen for high pressure low temp valves appear to utilise this method, but I cannot find any suppliers or sources of information. There is obviously something other than the Butt weld to secure the clamp but again no info.
Implications of low temperatures mean 'o' rings are eliminated too.
Is there anyone out there with experience in this area?
Ta
Bernard
Ta
Bernard
RE: Temp/pressure testing HP Butt weld valves
Hope this helps, 'NGL
A little different approach. You might want to give these people a call.
http://www.expansionseal.com/html/hypg1.htm
By low temp I mean -196 and high pressure is 1450psi or 100 barg.
The problem we have with plugs is that o-rings tend to be the sealing method.
I would imagine testing at high temperatures will have much the same problem.
B
B
