non-standard xfmr connections
1. Can anyone recommend a good text book (or online PDF) with solutions or articles that covers calculating phase shift in non-standard xfmr connections?
2. Can anyone recommend a good text book (or online PDF) with solutions or articles that covers calculating open delta connections?
RE: non-standard xfmr connections
IEEE C57.12.70-2000 and C57.105-1978 (R1999) are available online, but need a subscription to use. http://standards.ieee.org/catalog/olis/dtransformers.html
http://www.cooperpower.com/Library/pdf/R201902.pdf
///Please notice that the phase shift in transformer connection comes with the transformer design and it is posted on the nameplate. Are you referring to the phase shifting transformers for the multi-pulse VFD harmonic mitigation?\\\
///The open delta connections are actually formed. Please, would you be more specific about the open delta connection calculations?\\\
_______________________________________
Colin J Flatters BSc(Hons) IEng MIEE MIIE
Electrical Engineer / Project Manager
Email - cflatters@colin7.demon.co.uk.
