Lathe modernization concept
Hi! I am really delighted to join your engineering community!
Generally, yet I’m a post-graduate at Ivanovo State Power University in Russia. I’ve got a scientific task to solve the following problem. We have a simple 2-axis turret lathe with CNC – absolutely typical one: “X” and “Z” axes plus Spindle. All the motors are induction asynchronous ones.
The spindle gear-box includes 2 ranges of reduction and, accordingly, contains BACKLASHES (non-linear component); moreover, the spindle motor is connected to the shaft via belt transmission that is an ELASTIC component. The problem is to transform the velocity-controlled spindle into an additional position-controlled axis.
We can see 3 basic ways of the spindle control:
1. Across elasticity and backlash by taking velocity data from the spindle motor and position from the spindle shaft. Here, the position control quality seems to be poor.
2. By using another induction motor connected directly to the spindle shaft past elasticity and backlash. Here, we will lose on output load and the needed motor must be powerful and therefore of special design.
3. Trying to combine the two variants. Velocity-controlled powerful spindle motor plus position-controlled shaft motor. This way looks most interesting, intelligent, scientific and prospective.
The problem seems to be standard, so my interest is: perhaps, you would point out some solutions that already exist. Maybe, you will supply me with certain links on that subject or share your experience with me.
Hopefully, somebody replies my questions! Thank you!
RE: Lathe modernization concept
http://www.broadbentstanley.co.uk/cncflatbed.html
http://www.rmt.net/tenco/ver/
etc. for more info
http://www.mecha.osakafu-u.ac.jp/~syslab/teachers/sugimura/9802.PDF
for more info
