looking for product (Winn Viscotec)
I am looking for a product that I used about 7 years ago. My recollection is that the product name was Viscotec and it was made by a company called Winn.
My need is to find a suitable lubricant for pin & hanger on a bridge. The product was sprayed on (out of an aerosol can) initially had the consistency of a penetrating oil, and a few hours later it had a waxy consistency.
I would appreciate it if anyone can direct me to the above mentioned product or a suitable replacement.
RE: looking for product (Winn Viscotec)
http://www.indfloorcoating-repair.com/Grease-itliterature.htm
The product you are looking for sounds a lot like motorcycle chain grease. It is extremely penetrating when sprayed on and as the lighter stuff evaporates it quickly leaves behind a heavy grease. Ideal for lubing a motorcycle chain, penetrates into the side plates and pins of the chain and then evaporates to a grease that won't get slung out easily. You can get several different brands from most auto parts stores or any motorcycle dealer.
Timelord
http://www.wynnsusa.com/contact.asp
thank you
