Appropriate Frost Depth of Footings
What is the correct point on a footing's depth to be considered below frost depth?
Top of footing or bottom of footing?
Where would I find the code that indicates which of the two is correct?
Thank You!
Thank You!
RE: Appropriate Frost Depth of Footings
