1900's building-structural steel strength
I have a building in Manhattan from the early 1900's. It is steel construction with flat arch floors. What could be the structural steel members ultimate capacity?
RE: 1900's building-structural steel strength
Rivet Steel - Fy=25-30 ksi
Fu=50-60 ksi
Medium Steel - Fy=30-35 ksi
Fu=60-70 ksi
These above values are for dates up to about 1908.
For dates up to 1931:
Structural Steel - Fy = 27.5 to 32.5 ksi
Fu = 55 to 65 ksi
Rivet Steel - Fy = 23 to 28 ksi
Fu = 46 to 56 ksi
Source: AISC Rehabilitation and Retrofit Guide, (Steel Design Guide Series No. 15), Feb 2002.
You would be wise to get sample coupons from steel in the building and have them tested. Use the above values for preliminary work only.
what do you mean by rivet steel?
