Catia V5 and Catia V4 Car coordinates charts.
Hey,
Wanted to share some info. on point chart in V4 and V5.
In V4 I have put together a reported uisng the DIMCTl
macro in v4. If anyone is interested I can send the info. by email it is real extensive the list.
In V5 I found the Coordinate dimensioning table works for one point at a time. I need some info on multi selection in V5. I.ve tried the pwer input zone, but it dosen'tseem to work with that command any tips would be helpful.
Catusr
Catusr
RE: Catia V5 and Catia V4 Car coordinates charts.
I have been trying to set up the Reporter function in V4 to create a coordinate table. If you have any information that might assist me it would be greatly appreciated.
Brian Moore
bmoore@halla.on.ca
Thank you very much!
K. C. Takacs
der Entwicklungsingenieur/Design Engineer
Tesma International/Hughes Manufacturing
23300 Haggerty Road, Suite 100
Farmington Hills, MI 48335-2603
T: 248.888.5473
F: 248.615.7517
E: mailto:kc.takacs@tesma.com
http://www.tesma.com
Please send me too.
thank you very much.
cadesigner777@yahoo.com
would you be so kind to send me that info about the coordinates chart? I have to record hundreds of welding point coordinates some how for VW. I'm sure they have a kinda macro but I'm working at a suppliar office.
Thanks a lot
Robert
melak@eszes.de
If it is not too much trouble I would certainly appreciate getting a copy of the macro. I can definitely see I have use for it.
By the way is there any info on how to use it exactly?
Thanks in advance
Best Regards
David Ponder
Senior Design Engineer
VDA (Vechile Design Aust)
dave.ponder@vdae.com.au
I'm new to this forum and just getting reacquainted with CATIA v4, I was wondering if anyone knows where I should copy the two files: datum.reporter meas.reporter, to get the REPORTER function in CATIA to work. I have tried coping the files into the /catadm/CHRYSLER/db/ directory, but when clicking on the reporter button in CATIA, I receive the following error:
"Unable to allocate reporter file
Reporter file not defined"
Where should I copy the files too, and where would I define the reporter file?
Any help you can give would be greatly appreciated.
Thank you,
Anita
anita.braziel@magnasteyr.com
