Absolute & Relative References (Excel 97 Macro help, please)
In programming a macro, I would like to have an ABSOLUTE column reference, with a REALITIVE row.
Example,
I have 4 column locations I want to go (ie. C,Z,BB,CD). I want to make 4 seperate macros to go to the 4 seperate locations, with the following
condiditions:
a) I want to mantain my row position (ie. if the ActiveCell is "C11" and I run the "Z" macro, I want my final resting point to be "Z11"
b) I want to be able to run the 4 macros in ANY order (This is the part I am having trouble with)
One possible solution I had was if there were some command (within VB) that would sense where the ActiveCell was and be able to return a
row/column value. I could then use these values in a formula that would end up using the Scroll to move the screen accordingly command.
I am really in a jam on this, so I would appreciate any help or advice that you could provide.
Example,
condiditions:
RE: Absolute & Relative References (Excel 97 Macro help, please)
ActiveCell.Address wil give you the absolute adress of the highlighted cell.
To get the Row or the Column simply change Address in to Row or Column.
The return types of the Adress function is Range. This is just a string. For the Row and Coumn function the return type is a LongInt.
For example the highlighted cell is C11. ActiveCell.Address would return "$C$11", while ActiveCell.Row would give the number 11.
Now I think it's not so hard to select the right column on the right row.
Good luck!
Jonathan
Say we have the following Macros: MacroC, MacroZ, MacroBB, MacroCD - the names can be anything - I've just named them so their target column would be obvious. You'd write the code something like this:
In the Declaration Section of the module, put the statement:
Dim TargetCell as Range
Then write the macros:
Sub MacroC
Set TargetCell=Activesheet.Cells(Activecell.row,Columns("C:C").Column)
Do what u want with TargetCell in the statements that follow...
End Sub
Sub MacroZ
Set TargetCell=ActiveSheet.Cells(ActiveCell.row,Columns("Z:Z").Column)
End Sub
and so on...
Note that there's really no need to refer to the columns as "C:C" or "Z:Z" - simply using "C" or "Z" will also do.
All the best...
